juwalantz
Just wanted to ask around and see what air fuel ratio nytro riders were at when WOT. I'm running about 12.5 I would like to lean it out just a little more. Just want to see what anyone thought. I don't want to lean it out if it is going to cause me trouble
Running 11.8 at sea level on mcx 190 pump gas. If your at 12.5 I wouldn't lean it out any more. Why tease the angry dog.
http://www.ty4stroke.com/viewtopic.php? ... hlight=afr
http://www.ty4stroke.com/viewtopic.php? ... s&start=15
You will not want to run any leaner at WOT. You will find the explanations in the 2 links I posted for you.
TBird
- Dec 25, 2004
- North of Sweden
- Sweden
- Yamaha Viper and Yamaha Nypex
Some info of your sled would be required to be able to help you out, but as AnythingButLast say, read and you will learn all you need to know.
For an very low boost setup 12.5 isn't to bad, wouldn't go leaner tho especially if compression isn't lowered, for an high boost setup 12.5 is to lean.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Here's what I do:
AFR's at
Idle: 14.0-14.7
Engagement: 13.5
0 lbs boost: 13.0
5 lbs boost: 12.5
10 lbs and over: 11.8-12.0
Cruise AFR's may be as high as 14 even With boost at light throttle and load on the motor.
AFR's at
Idle: 14.0-14.7
Engagement: 13.5
0 lbs boost: 13.0
5 lbs boost: 12.5
