WFO or go home
What does MCX recommend for peak RPM?
Their dyno shows the peak HP at a higher RPM than the 7850 recommended by Yamaha.
Thanks,
Thanks,
woodsrider
- Feb 17, 2005
- Lewiston, ID
- 2017 YZ450FX1 Moto-Trax 137 Mountain Kit
You should be running between 8500-9000 peak rpm (Yamaha Spec). I try to run 8600-8700. If i get below 8500 I adjust my shockwave.
robertyoke
- Jan 23, 2008
i spin mine a 9000 and let the load pull it down to 8800 or so. rev limiter hits at 9200 or so
WFO or go home
Thanks for the info.
jaysrippen
I was also curious, just called Price George Yamaha, MCX distributer, they recommended 8650rpm for there 12# boost set up.
