Northernboy
I have the MCX240 kit with the head shim running at about 1000'. I am running at about 11 PSI on premium pump gas (91 Octane). I like the power but can I go more? MCX says max is 13PSI, but using the Boost spreadsheet 11 is 91 and 13 is 93. So am I save, should I add some Torco accelerator, so I go with meth? I guess keeping A/F ratios below 12 will help as well. Just wondering what save boost with 91 would be.
NB
NB
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
11psi is pushing it IMO, throw a dab of torco in and 13 is fine. If you do 13 I wouldn't hold it to the bar very long maybe 5-10 seconds a crack.
helmic
- Nov 10, 2008
- Bathurst N.B. CANADA
- 2014 Apex SE STUDED,PC5,D&D Performance Exhaust,MAX-REV intakes,D&D BullsEyes,Ulmer clutch kit.Yurbo coming soon!!!
boost
I run 12##on 91 but add 4oz of torco per tank and its working for me...
machzrobbie
Northernboy said:I have the MCX240 kit with the head shim running at about 1000'. I am running at about 11 PSI on premium pump gas (91 Octane). I like the power but can I go more? MCX says max is 13PSI, but using the Boost spreadsheet 11 is 91 and 13 is 93. So am I save, should I add some Torco accelerator, so I go with meth? I guess keeping A/F ratios below 12 will help as well. Just wondering what save boost with 91 would be.
NB
Pretty sure you have a 60 thou head shim + head gasket gives you .077 - plug that into the calculator and you get 13# @ 91 octane - and 11# @ 89.9 octane. I'm running the same shim on a MPI stage 2 and running 12.5 - 13 # on 91 pump gas.
Northernboy
The head shim is 0.075" and this is on a Nytro are the calculations right?
6 lbs = 84.9 Octane
8 lbs = 87.1 Octane
10 lbs = 89.3 Octane
11 lbs = 90.4 Octane
All at 1000'.
6 lbs = 84.9 Octane
8 lbs = 87.1 Octane
All at 1000'.
machzrobbie
Northernboy said:The head shim is 0.075" and this is on a Nytro are the calculations right?
6 lbs = 84.9 Octane
8 lbs = 87.1 Octane
All at 1000'.
sorry I did my calculations on a Apex - Nytro : with .075 shim I am getting different values than you - are you chaging the head shim values and adding the altitued??
Northernboy
Triplerev
What is your elevation?
Northernboy
Does anyone know where I can get some Torco Accerator in Ontario?
Northernboy
I found some and will be adding about 4oz per tank full just to be on the safe side. BTW loving the boost and would be nice to go higher!!!
TBird
- Dec 25, 2004
- North of Sweden
- Sweden
- Yamaha Viper and Yamaha Nypex
Add an fuelpump, an FPR and do a remap, voila 270hp.
Northernboy
TBird...Maybe next year....boost is addictive...
TBird
- Dec 25, 2004
- North of Sweden
- Sweden
Agree, i'm in the same boat
A while back, around a year ago, my boost fever was really bad, had plans to add meth, add a bigger turbo, beefing up the engine a.s.o. to start with i added some good fuel and rised boost as much my turbo could handle, what i noticed then was because i had to change my clutching to keep it off the limiter the sled got worse to drive in the trees and in really tight spot's, so right now i turned the boost down again, did some other mod's, and i'm really enjoy my 310hp Apex, what i want to say with that is that i believe that every sled / sledder has a sweetspot when sled and sledder works in harmony, that's how i feel anyway, hp isn't everything, it's every mod done to the sled put together working in harmony, do i make any sense, maybe little to deep?
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
TBird said:Agree, i'm in the same boat
A while back, around a year ago, my boost fever was really bad, had plans to add meth, add a bigger turbo, beefing up the engine a.s.o. to start with i added some good fuel and rised boost as much my turbo could handle, what i noticed then was because i had to change my clutching to keep it off the limiter the sled got worse to drive in the trees and in really tight spot's, so right now i turned the boost down again, did some other mod's, and i'm really enjoy my 310hp Apex, what i want to say with that is that i believe that every sled / sledder has a sweetspot when sled and sledder works in harmony, that's how i feel anyway, hp isn't everything, it's every mod done to the sled put together working in harmony, do i make any sense, maybe little to deep?![]()
man i totally agree....I liked me apex when it was 260 with stock pistons at 12psi then i do mine with lc pistons @15psi..... now im trying to get the throttle response back..cause we do alot of tree riding....good comment
