NJnytrortx
- Dec 9, 2009
I think I messed something up on the secondary when changing the belt on a 2009 nytro. I used the belt change tool to compress the spring, belt came off and went back on fine, but when I removed the tool, the spring did not pop back. Any ideas?
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Ya gotta wiggle that new belt around to get it out near the edges, It's holding the clutch open. Or, lift the track, start the sled and cycle the clutches for a second, should fix itself.
NFLD-Nytro
Crewchief47 said:Ya gotta wiggle that new belt around to get it out near the edges, It's holding the clutch open. Or, lift the track, start the sled and cycle the clutches for a second, should fix itself.![]()
Yep. The belt is down in the sheeves. As soon as the track spins it will come back up.
NJnytrortx
- Dec 9, 2009
Ok Thanks guys. Sorry for the noob question, it just make me nervous.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Did you put the belt on in the correct direction? You have to be able to read the numbers or stamping on it when you're facing the clutch side. Just wanted you to know that, because these belts are directional.
NJnytrortx
- Dec 9, 2009
Yeah, I made sure I put it on in the correct direction. Thanks for checking.
Zakre
Break her in nicely and usually they will last many miles of abuse before blowing.
