TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
Nytro XTX turbo: With the mid mount turbo being so close to the plugs, what is everyone doing to ensure that the plastic/rubber plugs will not melt? I have wraped these in heat reflector tape but wondering if there is other methods to protect these plugs.
Thanks,
Kevin
Thanks,
Kevin
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
Anyone?
spooled
never had a problem with this at all.
mtdream
wrap your turbo with a turbo blanket...
Did this, and it is a HUGE improvement....
http://cgi.ebay.com/ebaymotors/T3-T4-PT ... ccessories
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
mtdream said:wrap your turbo with a turbo blanket...
Thank you!!!!
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Allen ( ulmer ) ...would this fit and be benefical to your kit(s)?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
The only time I have seen any heat related issues is if the header bolts come loose. We are going to include a header/turbo/down pipe blanket on our kits for 2010. This will be piece of mind mostly as the first question I receive is about "heat" usually. This will retain all the heat in the header/turbo/down pipe where it is needed and actually help with performance some as well. I will post more details in the next couple of weeks.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Srxspec said:The only time I have seen any heat related issues is if the header bolts come loose. We are going to include a header/turbo/down pipe blanket on our kits for 2010. This will be piece of mind mostly as the first question I receive is about "heat" usually. This will retain all the heat in the header/turbo/down pipe where it is needed and actually help with performance some as well. I will post more details in the next couple of weeks.
nice allen! any way to retrofit to my kit?
- Apr 17, 2003
- Menno, SD
- Menno, SD
It will work on any of our kits from last season or any of the NW Turbo kits that are running the cast header & manifold. It is a direct slip on.
mtdream
yeah I had bolt issues, and my kit was a first generation NW turbo kit...
Subsequently I have added Stage 8 bolts, and the turbo blanket, and some other things, and have had NOTHING but a great year riding, and fun kit!!!
VERY reliable, but IMHO, any mid mount, would not ride without the heat blanket (especiialy spring)
but I am being OVERLY cautious too, several friends with same kit, have never had an issue at all...
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
Great info.
Thanks guys...
KI
Thanks guys...
KI
