Please post what sled and boost system you're running. It'll help us help you figure things out.
First thing to check is all of your air connections, both on your boost system, and the throttle bodies.
What does your fuel/ timing maps say you have for fuel changes at that throttle range? Is it set to add what percentage to your table? It sounds a little more like an intermittant rich condition actually, which an air leak could do, especially in a transitional or lower rpm range.
Also, what fuel are you using, how old is your wideband sensor, and was it calibrated per the instructions before installation?
To get to where you can correctly isolate the issue, you should start with the mechanicals first. Something like this can really be caused by alot of different things, even clutching. It could be bogging because the clutch is loaded too much at that rpm, or a number of other things that are coming to mind. I'd even check to be sure your ground is excellent on the PC5 too for that matter.
Post as much info as you can about your tune file, like when it starts adding fuel and how much, what sled and what boost system, and go over all of your air tube connections, etc, to make sure they're tight. Check all of your grounds, coil and injector connectors for corrosion, and make sure your plug gap is suitable for the boost level you're running. It might sound dumb and usless, but the smallest, most unheard of things can cause the biggest headaches..
