greenmtnboys
Hey guys Ive got a miss at about 12 to 15 percent throttle that seems like you are shutting off the ignition for a split second repeatedly and a rough idle (low and loaping) If I crack the throttle it takes off and sounds perfect. I changed my plugs and nothing changed ,battery is fully charged.I had a look for vacuum leaks and didn't find anything, disconnected the TORS no change.Getting frustrated
My tps shows 3% closed and 100% open on my dyno jet gauge
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Vacuum leaks, I fought this for 3 years and finally bought all brand new vacuum lines that go behind the TBs, and wouldn't you know it was a pinhole under a 90 degree prebent hose that was only visible when I pulled it apart. No idea how that got there. I know you say you 'checked' but they are insanely difficult to find, at least for me it was anyway. Ran smooth as butter after that.
greenmtnboys
ok I will go over the vacuum lines and check them very closely and let you know what I find.
greenmtnboys
ok vacuum line are good so I pulled the TPS and with a multi meter it doesn't seem to be working two of the wires black and blue you variation but yellow and blue does nothing? any experience out there
kinger
- Jan 17, 2005
- Clear Lake, IA
Unplug it and Black to blue should read 4-6kOhms at 68 degrees, then Yellow to black should show 0-4kOhm when you press and release the throttle.
greenmtnboys
Thanks Kinger Looks like I need a TPS
greenmtnboys
Changed out the TPS and the idle is good, going to take it out for a test rip tomorrow !!
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
kinger
- Jan 17, 2005
- Clear Lake, IA
Good work! Now go have fun!
greenmtnboys
Just an update miss is still there but It looks like my air fuel sensor has packed it in and is messing with the auto tune. So that's the next step. Its pretty cold for sleddin right now anyway
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
Well that won't help matters. Keep chipping away when you can.
kinger
- Jan 17, 2005
- Clear Lake, IA
I could never get O2 Sensors to last. I had it mounted at the right angle, and took care to let it 'heat' up on key start, never mattered. After 1000 miles or one year it was done. I would never engine management based on O2 info again. Even on my Motec I will run in open loop to stay on the map vs closed loop on a O2. I will log the O2 and trust the readings until it craps out. Good luck!
greenmtnboys
It was the 02 sensor, thing is back and ripping up the snow
A
- 12K
A
- 6K
