Mono drag setup
Charged RTX
Southern NH
Do you guys have any tips on how to set the mono up for drag racing. If it transfers as much as they say I would assume cranking it up all the way would be to much. I don,t want the skiis 3 feet in the air and everyone goes by. Do I loosen the spring, drop the limiter?
Without riding it yet on snow. I'd say at most you'd have to do is tighten up the limiter strap 1 hole.
If the 06 Apex is setup like the 05 RX-1 was for the limiter strap setting, then it will likely transfer too much weight for you to begin with.
