Mono Shock Adjuster Tool...alternative to cable replacement NOW IN STOCK
hibshman25
Vendor
Age
40
Lebanon, PA 17042
2017 sidewinder ltx dx
2018 snoscoot
For those that gave up on replacing the the mono shock adjustment cables we have designed a small tool which allows for easy shock adjustment.
To utilize the tool, the shock eyelet must be rotated 180 degrees so the port is facing downward.
Tool is stainless steel and will come on a key chain which indicates which direction to turn for harder or softer setting.
Also included will be a rubber cap to install over top of the fitting when not being adjusted.
Sell Price is $35
I need 2 of these... every year the cables are broke. How much? You should also make a blank off panel to just remove the adjuster.
I need 2 of these... every year the cables is broke. How much? You should also make a blank off panel to just remove the adjuster.
Still waiting on pricing back from laser fab shop. Will certainly be cheaper than a new cable. Thinking around $35 retail.
Will work on drawing up a block of plate and get some pricing on them too. If there's enough of interest in them I will get a batch made.
Travis just spent $47 cable re placement that just small part done it three time
Travis sent me 1 this winter, works well, but I need the cap for. Covering shock tip.
TRAVIS did you find me a 13mm sway bar yet RX1, Larry
Hey Larry. Got 4 sleds in last week. If one of them has a 13mm you will be first to know!
Your shock adjust tool was one of the early prototypes. Once we get the final version complete I will send one out for you with the cap.
Travis thanks so much (I appreciate your help), just wanted guys to know tool works great, will hope ya have a 13, Larry
Shock adjuster tools are in stock. Will be selling for $35. Still working on block off plates.
Block off plates are now in stock. The plate will mount on inside of tunnel using the 3 ra adjuster mounting bolts. The plate comes with flanged lock nuts. We are including the plate and nuts with the adjuster tool as a kit. We will also sell the block off separate.
I would like 2 kits with plank offs... can you set me up?? I can run your logo on my asphalt sled if you send me 2 stickers with it :)
Anyone have a extra key?
Do you know kimpex makes a knob for the adjuster now that screws onto the shock&stays there, you can just turn in or out to adjust
