gas n go
Has anyone moved the clip position on their monoshock without removing the shock from the skid. Apparently it can be done if you compress the spring with a ratchet strap. Has anyone done it? If so how difficult?
06RTXTASY
I would not recommend even trying that with a ratchet strap. Its a good way to lose a finger or two. It such an easy fix to remove it yourself on the ground. Once you take it out bring it to your dealer to have them do it if you don't feel comfortable disassembling the shock. IF you do it your self then spend the money on a spring compressor (like 70 bucks i think) but then your back at the dealer because it will be cheaper to bring the shock assembly down and have them do it.
hemiram
i use two straps when i did mine in 15 min
sobfrogg
It can and was done with a spring compressor. See you local MATCO tool truck..
Much safer than ratchet straps but the ratchet straps will work
gas n go
Spring compressor on the way. Will the clip adjustment keep a 210 pounder from bottoming??
sobfrogg
Sure will.
I have mine on the 3rd clip and I have the High rate spring.. I am 240 + gear and like to jump.
