mono skid mesurment
sickboyz_yamaha
sheboygan, WI
So I'm working on putting my 06 Attak mono skid in to a 02 viper..I read a bunch of how to post but I think the mesurment of the back mounting point arm width is different from the 121mono to the 136 mono.. can anyone tell me how wide that arm is without the shaft, just the arm?
Thanks for any help
Just measured the width of just the shaft on my rear arm, which is out of the skid. I measured 15 3/16". This is on an '07 AttakGT. Hope that helps.
I actually need the mesurment of the arm not the shaft...I need to know if my 136 skids arm is wider than a 121 skids arm...
I don't know the measurement but the Attak rear Arm is wider because the top wheel support is behind the shaft on the tunnel bracket.
The 121" got the support wheels mounted on the shaft.
That is the measurement of the top cross member of the rear arm, not the shaft inside (or bushings) The shaft itself is removed, as are the bushings.
