jclee71
Have an 06 apex gt, think i went to stiff on the spring(6.5) and revalve(Pioneer), it rides stiff and that on softed EC setting, is this the spring or valving causing the stiff ride, can i put stock spring in with the new valving, I know the 06-07's came with the 4.9 spring, is it true new apex's have the 5.5 stock?What to do?
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Ted Jennety Clutching, jetting, air box mod.
Arctic Cat Z1 Turbo 128" Rear Suspension
128" Hacksaw 1" track.
Heated seat
I have a 05 RX1 and it use to bottom out all the time. I had a local shock guy rebuild and revalve my shock, no spring change. Now it dosen't bottom out and ride good.
Maybe you would have been ok with just the shock job.
Bruce
Bruce
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
I have the 5.5 spring let you have cheap.jclee71 said:Have an 06 apex gt, think i went to stiff on the spring(6.5) and revalve(Pioneer), it rides stiff and that on softed EC setting, is this the spring or valving causing the stiff ride, can i put stock spring in with the new valving, I know the 06-07's came with the 4.9 spring, is it true new apex's have the 5.5 stock?What to do?
jclee71
I think he set me up with Yamaha's scandonavian set up, what valving is that?
apltx08
Here's a set-up chart...
http://www.ty4stroke.com/viewtopic.php?t=42866
Here's good info on Mono GT...
http://www.ty4stroke.com/viewtopic.php?t=20318
How aggressive,how do you push the machine,how do you ride?i have a (6.5) in mine and use it when the times get rough.when i jumped the banshee years back(now its a drag quad) i had it stiff valved/sprung cause of hard/high landings worked great.i weigh 185 wet,i know when it gets nasty or if i wanna jump the [ground shaker] it will take it to an extent.its ALL about you.i have riden on other APEXs and they all feel different.i also factor in gas ,ice,misc.6.5 works great for me...jclee71 said:Have an 06 apex gt, think i went to stiff on the spring(6.5) and revalve(Pioneer), it rides stiff and that on softed EC setting, is this the spring or valving causing the stiff ride, can i put stock spring in with the new valving, I know the 06-07's came with the 4.9 spring, is it true new apex's have the 5.5 stock?What to do?
