NB-NYTRO
I love my GT overall. It pulls awesome down low and midrange but my top end is nothing to brag about.. What can I do to get it to run a faster top speed without spending big $$$?
welterracer
You have PM..
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Not much without more power. I would try gearing down to a 23 tooth on top. I takes lots of power to go faster! Think turbo.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
nb-viper said:I love my GT overall. It pulls awesome down low and midrange but my top end is nothing to brag about.. What can I do to get it to run a faster top speed without spending big $$$?
check my threads and signature....
-1inch track
-light studing(96)
-RAM AIR(one of the biggest gains)
-clutch kit(dalton red with DPYRs)
-dalton helix
-machine clutches
-23 tooth top gear.
-synthetic oils in motor and chaincase
-windage plates
to gain top speed on these sleds...you need to do alot of little things to make MPH...doing one or two of the above wont work...you need to do alot more.
dan
NB-NYTRO
I think I found the culprit. I have several bad idler wheel bearings that are almost seized. My local Yamaha dealer recommended an going to an aftermarket Doo wheel that I can change the bearing later on if necessary. They want $54 per wheel for the Yamaha wheel. Thats crazy...
SledFreak
- Feb 7, 2005
- Ontario. Canada
Put the doo ones on...
http://www.ty4stroke.com/viewtopic.php?t=34078
Also drop to a 23 top gear. It will help mid and top end a little.
- 7K
