Motec Standalone ecu
FLYBYU
south elgin, il
I should have it mid next week. I'll post some pictures of the install and reviews. So far Martin has been awesome. Answering all my emails and questions even on the weekends. I went with the M400, 1000cc injectors, unlimited data logging, boost control, anti-lag, traction control. Yes it was pushing the $4,500 mark but I'm so tired of these piggyback systems that only do a fraction of what this does. And the all factory dash functions work with no more hand warmer helpers as this eliminates that. More to follow.
There's 2 other guys on here that have them also. I know one is on his way hay days but were going to share some pictures and reviews on this. What's nice is you can do datalog runs on your laptop and watch the pulls on a graph. (TP%,BOOST,AFR,SPEED,ENGINE TEMP,AIR TEMP) and others the you want. Theirs a gps option also if you want more precision mph.
I do have one motec ecu into my turbo mountain apex...
unfortunately, I don't really use this sled anymore... so its pretty useless for me. loll
Wanted to share some pictures. This is where I mounted the ecu. The factory dash works normal. Low fuel light because I drained all old fuel out. New AEM gauges that work with ecu. Reinstalled rear heat exchanger on Muffin Works tunnel ext. Tuning is going great
You running at Belvidere ?
I would've like to but don't think I'll be running, just helping someone else. I have a screwed up neck right now. 3 bulged discs. Don't think that would help it. The launch would be brutal. Are you going?
I'll be there! Last yr. the WHOLE family went and the girls were bored lol! Imagine that.
I also wanted to add also I installed 1000cc injectors as well. Had to make some spacers as injectors are taller than stock. Perfect idle with these.
