Matthew457
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
I have them...make sure you buy a turn out and I added reflective tape to right side. I also moved the pin closer to the right so the tanks wouldn't slide over into exiting exhaust. I haven't blown up yet...over 1000 miles with them on. Think I'm going to fab a shield this year to block more exhaust. I ran my wires under tunnel...used square tubing from tunnel protector to run wires through...let me know if you want a pic.
Matthew457
Awesome! And yes, pictures would be amazing! ThanksView attachment 109745
Matthew457
Also, I was thinking of putting the tanks facing sideways, so the caps stick out facing the left side of sled from the back. I think that it would leave more room by the exhaust. I lined it up with the ones my brother has and it seems like it would work out a bit better.View attachment 109745
Matthew457
The sliders would go on like that, with one as far as possible to the leftView attachment 109745
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
Good idea...I'd like to see pics (you might have problems clearing the tail light but an LED strip would solve that)...I'll try to get you some pics of under the tunnel sometime this weekend.
Matthew457
Ok cool thanks, and I was thinking about maybe putting a spacer or something inbetween the bolts so that the sliders will be a bit higher up so it will clear the taill light. Will see what works when I get it.Good idea...I'd like to see pics (you might have problems clearing the tail light but an LED strip would solve that)...I'll try to get you some pics of under the tunnel sometime this weekend.
SnoBird888
since the tail light points up in that position i made 4 plastic wedges, two for outside tunnel and 2 inside. drilled them so the screw went straight through and now the light faces straight back.
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
Matthew457
I put the light upside down lol, but that's a good idea, I may just drill holes lower if I have toosince the tail light points up in that position i made 4 plastic wedges, two for outside tunnel and 2 inside. drilled them so the screw went straight through and now the light faces straight back.
Matthew457
Cool thanksHere you go...
Matthew457
got any pics?since the tail light points up in that position i made 4 plastic wedges, two for outside tunnel and 2 inside. drilled them so the screw went straight through and now the light faces straight back.[/QUOTE
SnoBird888
I can try if I get up north in the next couple weeks but you basically take a small cube of plastic. drill a hole down the center of say the front side.. then along the left or right side of the cube cut it through corner to corner. you now have two wedge pieces. Then you just get creative with the angle so it points straight back and not up at angle. Of if you can find small enough ones buy beveled washers.
Matthew457
Sounds great, thanksI can try if I get up north in the next couple weeks but you basically take a small cube of plastic. drill a hole down the center of say the front side.. then along the left or right side of the cube cut it through corner to corner. you now have two wedge pieces. Then you just get creative with the angle so it points straight back and not up at angle. Of if you can find small enough ones buy beveled washers.
yelldoo
Here you go...
How do you have the channel on the under side of the tunnel with the wiring running thru it held to the underside of the tunnel......?Here you go...
