Apex809
Have a mountain vector. Lost spark on pto side. Have changed plugs coils and voltage regulator. Any other ideas? Thanks for the help.
Apex809
Ohm reading on the stator are .2 to .3 on both sides. Is this correct?
Apex809
Check ohm readings on stator got .2 to .3 Anyone have the reading?
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
. 22 to .26 ohms for the stator resistance. There is no spark on just one cylinder?
Apex809
Yes, no spark on just the pto side.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Which cylinder exactly? Sitting on the sled from L-R? 1, 2 or 3?Yes, no spark on just the pto side.
Apex809
The one closet to the PTO CLUTCH SIDE.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
OK...#1
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
what year vector?
Apex809
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
The coils are all powered from the key switch so with the switch on there should be 12 volts on the brown wire to each coil. The second wire on each coil is a ground signal that pulses the coil causing it to discharge. The ground signal for each coil is individually controlled by the ECU. If you don't have the proper signals at each coil and the wires are good the problem is probably a faulty ECU.
Apex809
Thanks it was the ecu.
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
Nobody argues with the "GRIZZ".
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
I know there's a ton of knowledgeable people on this site but I know I can always count on Grizztracks for help. I hope that the site somehow maybe shows their appreciation (free VIP membership?)!
