jw440/800
I need some help wit the play sled, I can not keep sliders on this sled. I tried different sized wheels, but they didn't hold up the just blew apart after a few hundred miles. What is everyone doing to keep the sliders?
I'm thinking about trying the Excell wheels, anyone try these?
jw440/800
any out there?
RX1Jim
The Excell oversize wheels, or any oversize wheels or the wheel lowering kit from Pioneer will improve the hyfax wear a great deal. I made a set of offset bushings for the stock wheels that lower the wheels by 2 mm. I can now get several thousand miles of life out of the hyfax. The key is to get the bottom of the wheels lower by 2 - 4 mm. I made this modification to my RX-1 and two SRX 700s. Same results, excellent hyfax wear, no more melted hyfax.
wkeggenhoff
- Dec 20, 2007
- Ajax,Onatrio, Canada
- 2006 Yamaha Apex RTX
excell wheels
Just did the Exceel wheels on my apex as well added the extra wheel at the rea due to the fact that I stretched it to 128" hope it helps because I burbn through 2 sets a year normally
ScottyD
- Mar 2, 2008
i also did excell wheels last year on my rtx, adding an extra 2, greatly helped with the slidewr wear
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
What suspension?
Super Sled
- Feb 25, 2009
- Summit X
Also, if you have 144" or shorter rails and run a fully clipped track, Yamaha will be selling the DuPont Vespel sliders here in a month or so.
Pricey sliders, but are supposed top last far longer than current sliders. I guess you do need a fully clipped track for them to work tho.
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
Scatchers help a lot. A friend went through a set in a day in Canada. Put the rail mounted scratchers on and after a week they were like new. That is on a 151"x2".
bummerman
174" track with no wheels and I havent burned out my hyperfax yet. Used to go through two sets of stockers a year. Stay away from graphite hyfax I've killed those in a matter of hours.
quebecmoutainrider
my wifes attak 136 and my 162 by 2 and a half. yammie..scratchers on the trail all the time..over 2000ks still half left..no wheels on mine....when I got my new mountain it came with scratchers on.Ratpack said:Scatchers help a lot. A friend went through a set in a day in Canada. Put the rail mounted scratchers on and after a week they were like new. That is on a 151"x2".
..hmmmmRatpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
Stupid question but---why do you have the wheels off?
