MPI Stage 1 PCV map
Ontario
Canada
2017 Sidewinder RTX LE
Would anyone happen to have a dialed in PCV map for a 2011+ Apex running 10-12psi on an mpi supercharger?
Thanks!
I have a map for that application if you haven't found one, but I'm not sure about the altitude difference , if your not running a/f or autotune for safety.
Hi would it work for a 2011 Apex mpi SC with stock injectors? I'm only running 7lb of boost
I would really appreciate you sharing it. I do have an autotune as long as it's close lol.
