MPi Supercharger for flatlander fuel / boost Question
Plus Man
Frankford Ontario
Looking at putting a stage 1 mpi on my Apex running 7ibs of boost on stock motor riding 325ft above sea level. I do lots of trail riding and was wondering will I have any issues as I can only get 91 octane. Also what do you do if you only get 87 octane can you still limp it home. Or can you add a octane Boost and drive easy low rpm. Looking at all the cons and pros with performance and reliability sled has 4000 miles on stock motor and not have enough go . Any comments !
I'm at around 500ft, I think. I have a stage I on my Attak. All I run is 93, 91 I'm not sure off. Should be okay. Just watch your knock sensor. For sure do not add Octane boost. It will fry out your A/F sensor....and these are around 80 bucks a pop. You'll have to run some type of wideband for sure for tuning purposes.
Good luck, Boost is addicting. I'm already thinking about a stage II. Do yourself a favor and if you do decide to buy, just guy the stage II. You can run low boost on that as well. I promise you, you WILL be wanting to crank her up.
I plugged your info into the boost calculator (attached). You're a bit low on octane according to it, but my experience is that you should be OK on 91 if you aren't giving it sustained WOT pulls.
I agree..go with the stage 2..Trust me you will want to turn it up!!
rode 120 miles today on premium fuel that was availble in the boonies.
If you have to run reg just stay off the pin.
Do it . you will love it
