Joey P
- Dec 12, 2014
- minocqua
- APEX XTX SR Viper XTX
I'm new to turbo sleds and I was wondering if my viper is supposed to backfire
No its not suppose to backfire... I would guess the fuel settings are not right.
Zampinator
- Nov 22, 2014
- Gaylord, MI
- 2015 Viper XTX LE
No. Sounds like your running a little rich
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Is it hitting the rev limiter?
Joey P
- Dec 12, 2014
- minocqua
Yes it's hitting rev limiter it's set to 5lbs of boost it only happens if I hit the gas and let off right away only happend probably 3 times
Joey P
- Dec 12, 2014
- minocqua
I called my dealer hes going to adjust the fuel controller
Joey P
- Dec 12, 2014
- minocqua
Where should my AFR be at 55mph at 5lbs of boost im at 9.7 and if I go full throttle im at 10 and when I'm at idol im at 14 then again I'm using the Koso x2No its not suppose to backfire... I would guess the fuel settings are not right.
Kerrdog569
- Sep 11, 2014
- East jordan,michigan
- 2017 Yamaha sidewinder xtx se
Not telling ya what to do but some other guys used that gauge and had major issues,your afr # should be between 11.5-12.5 according to mpi,I bought the AEM gauge and mine #'s are in that range and no back fires and it's starts cold or hot perfectly,make sure your dealer shows you how to adjust the GEM controller,does the Koso sensor require fre air calibration?my trail turbo is @11.5 @55mph
Joey P
- Dec 12, 2014
- minocqua
The dealer put it in a dumb spot so I couldn't mess with it you push mode and the arrows ping left or right right they never messed with it so I don't k ow were im at and im away for a week right nowNot telling ya what to do but some other guys used that gauge and had major issues,your afr # should be between 11.5-12.5 according to mpi,I bought the AEM gauge and mine #'s are in that range and no back fires and it's starts cold or hot perfectly,make sure your dealer shows you how to adjust the GEM controller,does the Koso sensor require fre air calibration?my trail turbo is @11.5 @55mph
Kerrdog569
- Sep 11, 2014
Kerrdog569
- Sep 11, 2014
So are you familiar with the GEMS controller?
Joey P
- Dec 12, 2014
- minocqua
No not at all im new to the whole turbo thing I don't know if I'm running rich or leanSo are you familiar with the GEMS controller?
Kerrdog569
- Sep 11, 2014
Ok it's actually quite easy to adjust you just need to move it so you can see it,go to mpi's website and under the support heading at the top go to the nytro section and see the GEMS controller set up,it will explain how to do this,right now your running too rich and the backfire is excess fuel in the exhaust
Joey P
- Dec 12, 2014
- minocqua
is there any way i could be running to lean because the dealer said he didnt change the settings on it at allOk it's actually quite easy to adjust you just need to move it so you can see it,go to mpi's website and under the support heading at the top go to the nytro section and see the GEMS controller set up,it will explain how to do this,right now your running too rich and the backfire is excess fuel in the exhaust
If the gems was not changed then its most likely set in the middle...
