SilentSno
- Mar 6, 2007
- Montana, USA
- 2008 Yamaha FX Nytro MTX
It wasn't very difficult. I didn't drill out the holes. This might have been wrong, but it worked for me. I know Nikolai did and didn't have any issues either.
I just put one bolt in at a time when its barely threaded into the adapter, then i pick the next one, and so forth. Then slowly tighten each one a little bit at a time.
Hope this helps. If not, try posting a picture for us to examine.
Nikolai
Saskaboy said:Silent and Nikolai,
How much of a pain in the azz to put the adapter on? I drilled out the holes like the kit says and it doesn't align at all. WTF????????![]()
Did you guys have that problem?
make sure the Powermadd box was checked off for Yamaha(on the back). I can't think of why it wouldn't align except for it's the wrong adapter.
DITCHBANGER
i had the kit marked yamaha,everything lines up and the bolts were the same size as well
Saskaboy
- Sep 23, 2007
On the back of the box the Arctic Cat in marked off but the guy at the dealership i bought it from said the cat and the yamaha ones are the same......... maybe they aren't!!!!!!
Cause it is not lining up. I tried doing on bolt a little bit at a time and that didn't work. As soon as they start to get tight, the whole adapter goes all cackeyed
errol
- May 24, 2003
- Quebec, QC
- 2018 SW B-TX LE 50th
Mine did fit perfectly!
Errol
Errol
Saskaboy
- Sep 23, 2007
Yup wrong # and part. Piece o chit!!!! I think a 4" riser will work perfectly for me once I finally get it on there!!!!!!!!!
nytroryda
wow after looking at this thing its almost like i was eating viagra like skittles!!! lol
