tkuss
I have my 06 RTX set up just the way I like It right now, but I am still wondering if any body has had there sled set up so that the skis get into the air when taking off. I believe my limiter strap has two holes left in it to make it longer, and sometimes I set the transfer rod to full max just for the fun of it. But with the transfer to full and two holes left in the limiter straps the skis might get off the ground an inch for a second or two, but they defiantly are not getting a foot of the ground like I have seen some pictures of on this website. I am just wondering if loosing the limiter strap makes that big of a difference in doing wheelies.
MUSKIE
- Dec 21, 2006
- SW Ont.
- Custom - 06 Apex
ARE you studd :exc: ed ???
tkuss
Yes 144 studs
AIRWOLF
Guest
- Oct 1, 2004
- New York
- www.sledpartsgarage.com
WHAT LENGHT STUD?
YOU SHOULD BE ABLE TO FLIP THAT SLED OVER ON FULL TRANSFER
STS
I weigh around 225 with gear on, my transfer is set at 1 notch past half-way on the supplied guage, clip in 2nd position and adjuster is set to 3 clicks down from full, and I have no studs. I can get that thing to lift the quite high hardpacked snow. It lifted so high a few times on me last year that I had to let off, it was starting to twist like it was going to come down on it's side.
Steve
Steve
MUSKIE
- Dec 21, 2006
- SW Ont.
- Custom - 06 Apex
AIR WOLF is right on!! That sled should stand right up on FULL transfer with studds.
last year my rtx would point straight to the sky when racing,and it wasnt a slight pull straight up that sumbeetch shot straight in the air, bone stock,no studs...finally got it to settle down
badluck
- Feb 6, 2006
- Ballston Spa, New York
- 06 Apex RTX S/C
09 Nytro RTX
HEY RED800, HOW DID YOU MANAGE TO KEEP THE FRONT DOWN? I'M HAVING A HELL OF A TIME.RED800 said:last year my rtx would point straight to the sky when racing,and it wasnt a slight pull straight up that sumbeetch shot straight in the air, bone stock,no studs...finally got it to settle down
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
Re: My sled is set up good, but I still need to know one thi
Given your set-up and the different things you have said youv'e tried, I am going to suggest you check your belt deflection/condition. You may not be starting out in 1st gear!
tkuss said:I have my 06 RTX set up just the way I like It right now, but I am still wondering if any body has had there sled set up so that the skis get into the air when taking off. I believe my limiter strap has two holes left in it to make it longer, and sometimes I set the transfer rod to full max just for the fun of it. But with the transfer to full and two holes left in the limiter straps the skis might get off the ground an inch for a second or two, but they defiantly are not getting a foot of the ground like I have seen some pictures of on this website. I am just wondering if loosing the limiter strap makes that big of a difference in doing wheelies.
