Jensen
hi, my warrior is overheating when i drive on hard snow. I havent got a rear cooler , and need help to find a cooler. Need the part number . And what is the best cooler.
Thanks for the help and happy hollidays.
Ej from norway..
Ej from norway..
ken_climb
Got scratcher's????? if not get'm!
Turk
Tech Advisor
Get the scratchers that mount to the rails, not the tunnel. They really extend slider life & help cool everything off.
Turbo Tim
make sure all the air is out of the cooling system........maybe air locked
yamamax
Turk, what brand do you recomend?
Turk
Tech Advisor
SLP has a good set that works well.
yamamax
Turk, I went on the SLP website but did not see any scratchers that mount on the rails.
Mountaintech
Jensen, check the specific gravity of your coolant and make sure the antifreeze content is not too high. Do you have scratchers? If not, get 'em!!! Yamamax, the best scratchers I have found are made in BC. They are called Sinco's. They are available through Vision Motorsports @ 604-894-6840. They are rail mounted and my RX1 Turbo has never overheated even on 8 kms of rockhard ice road with a 2.5" track!! Use scratchers religously. Oh, took out all idler wheels as well and still get 3000kms or a season out of my sliders.
Jensen
Gone get the ice scratchers and a rear cooler.
Thanks for the help guys!
Jensen.
Jensen.
