Just wondering what a guy has to do to remove/replace the front inner idlers on a nytro xtx....im thinking you have to remove the front shock from the top mount, I took all of the preload off of the spring. The skid is on the sled yet..
Im adding 4 "X" wheels to the rails. I already have 4 ski doo 135 mm wheels in the stock locations on the outer rails. Im adding a pair behind the torsion spring mounts and the stock location inside the rails in line with the front shock....any insight or direction would be greatly appreciated.....
when I did mine, I just unbolted the axle and used a pry bar to compress the shock/pry the axle out of the skid...then simply pulled the wheel off and changed it.
