Need Brake light wiring diagram
nitris223
Yorkton Saskatchewan
Canada
Yamaha Nytro MTX
Does anyone know which wire on the brake light is the ground, running light and brake light. I want to install a new smaller brake light and relocate it to the back of the tunnel where the reflector is. Only if I can find was for a Phazer and it was Black is ground, Blue is running light and yellow is brake light. Is the nytro wired the same.
I believe those wires are correct. To be sure you could test the wires at the plug, I changed mine last year but forget which wire is which now.
They are correct , got the new tail light wired up and working. Thanks guys.
I will post some pics when I get a chance. Working on both sleds right now. Both sleds are getting HID lights, powerclaw tracks, night rider brakelights and 2 different graphic kits. Hope to have everything done by Friday for our first ride of the season. In between I have to finish a arm bushings on my neighbor's nytro and swap a track on another friends nytro.
Here is a picture of the brake lights I installed. They are from Custom Dynamics and is called the knight rider. I think next time I would go with the clear light and not the smoke lens. They are bright but our sleds make such a snow storm behind them I don`t think it would matter what brake light was back there.
