superbeast
measured it 4.48 volts , checked all connections n nothing looks bad , battery at 12.4
need help bad !!!!!!!!!!!!!!!!!!!!!!!!
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
what is at 4.48 volts?
superbeast
tested the the sensor like service manual says , manual says 4.8 or more
superbeast
and it turns over but dont start , checked battery , checked ground on motor , took it out wiped it off , tested it with switch off n says 0.00 , with switch on reads 4.48
