superbeast
measured it 4.48 volts , checked all connections n nothing looks bad , battery at 12.4
superbeast
had motor out to fix cracked header n ran perfect before that n only has 2000 miles on
superbeast
and it turns over but dont start , checked battery , checked ground on motor , took it out wiped it off , tested it with switch off n says 0.00 , with switch on reads 4.48
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
Its hard to say even though the sensor does read the correct voltage, the sensor could still be defective, but I'm going to guess that something else is causing the issue.
Have you checked the ground on your piggy back box? The sensor signals pass through that, and if it's not grounded, it won't pass the signal through. I've done that one a couple times, it's an easy one to miss.
superbeast
Where is that ?
11apex
- Feb 3, 2013
Just something to check but cam sensor and speed sensor have the same plug!! Ask me how I know
superbeast
How do u know ?
R u serious ? R the plugs the same color or is one white n other black ?
superbeast
THAT WAS IT !! THANKS A TON N BOY DO I FEEL LIKE A IDIOT !! N worst part is I just bought a sensor n a ECU
