MarkRTX
I'm sure I'm not the only one this has happen too. Went to change my slides out and to my surprise one of the screws that holds on the slide was shheered off so now I have a broken bolt and no way to grab onto it any ideas how best to get it out? I'm thinking drill it out but want some input first thanks Mark
Wisconsin
I'd think screw extractor...
http://www.menards.com/main/tools-hardw ... 465810.htm
If it's completely flush you'll have to drill it out and use the extractor. If not, you might be able to clamp a vice grips on it and turn it out.
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
Try the bolt extractor if you want to try and save the set up that you have, but I would recommend the upgrade that Rockerdan did where you make a hole in the rail and use a nut- see the thread below.
http://www.ty4stroke.com/viewtopic.php? ... light=mono
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
yes drill it out and drill a hole in the sid and ues a nut do both sides right away so you dont heve same prob down the road with other side
