Need help installing 136 ZR Cat skid in Apex
Ed
I found the template after looking through a million posts. Click on pic below to blow up, then print it off.
Also, like I mentioned earlier, you will need to take a bit of material off then ends of both sides of the front shaft so it will fit up in the tunnel. Well, at least I had to. Before permantly mounting your rear bracket, take a measurement from front shaft to rear shaft, just to make sure this template will work. Call me if you need more info.
Bigblue said:
looking for tunnel hole dimensions to install 02 zr 136" cat suspention into a 06 apex? Thanks.
I just saw this, I installed a 2006 Crossfire skid into my 07 attak. The post is back a page or two of all the information.
aj
