turbine man
I HAVE A BENDER TURBO 2560R ON A STROKER 05 VECTOR FINALLY PUT A O2 GUAGE ON IT. RUNS IN THE 12S 30 TO 40 MILES PER HR, WHEN I GET INTO THE TURBO IT DROP DOWN INTO THE HIGH 9S. PEDO JET IS AT 370 , HAVE NEVER HAD THE CARBS APART TO CHECKTHE JETTING. EXHAUST PIPE IS ALLWAYS LIGHT BROWN WHEN TRAILING RIDING IT, FIGURED I AM NOT MAKING PEAK HP RUNNING ON THE TURBO. ANY HELP WOULD BE THANKFULL JEFF
BigDog05
Do you mean WOT when you say get into the turbo. If WOT, I would put in a bigger pitot jet. Most agree it takes 50-100 changes in pitot jet to see a difference on A/F gauge. Try a 420-430 and keep increasing until you get high 11's, very low 12's depending on how much boost you are running.
turbine man
turbo
YHANKS I NORMALLY RUN 10 LBS IF I HAVE BETTER FUEL IN IT I WILL RUN 18# I WILL TRY A LARGER PETO JET FIRST. ONE OTHE QUESTION MY TURBO WILL NOT MAKE MAJOR BOOST UNTIL IT IS REALLY WARMED UP , TAKES SEVERAL PASSES THEN ALL OF A SUDDEN IT MAKES MORE BOOST WITH OUT CHANGING ANYTHING.
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Re: turbo
Could be an exhaust leak that is closing up when gets hot...turbine man said:YHANKS I NORMALLY RUN 10 LBS IF I HAVE BETTER FUEL IN IT I WILL RUN 18# I WILL TRY A LARGER PETO JET FIRST. ONE OTHE QUESTION MY TURBO WILL NOT MAKE MAJOR BOOST UNTIL IT IS REALLY WARMED UP , TAKES SEVERAL PASSES THEN ALL OF A SUDDEN IT MAKES MORE BOOST WITH OUT CHANGING ANYTHING.
turbine man
TURBO
SO YOU ARE SAYING IT SEALS UP WHEN ITS HOT LETTING THE TURBO TURN FASTER MAKING MORE BOOST. SOMETIMES IT MAY BE 10/15 MINUTES BEFORE IT WOULD MAKE HIGH BOOST.
turbine man
TURBO
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
turbine man - please turn off CAPS LOCK on your computer, hard to read in upper case letters.
sincerely
rxrider
TY Management
sincerely
rxrider
TY Management
turbine man
turbo
just tried a 450 jet in the pedto tube had a 370 in it, a/f guage now reads a touch over 10, do i keep going to try to reach 11.9. 12lbs boost 93fuel with a splash of 110. wot will this change my trail riding a/f reading thanks jeff
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
I'd go another 200 on the pitot jet. Ken...
turbine man
turbo
thanks will give it a try
