Need info on how to re-wire a new original hand warmer
NorRX1M03
The cable going from my left hand warmer is just 3 cm long, and not working wireless :)
The previous owner probably rolled with the sled, and ripped off the cable
I have bought a new warmer assy complet with the switch and stuff for the left side on my 03 RX-1 Mountain.
The problem now is how to re-wire this unit under the hood. I can't see any signs of the previous wires. The previous owner had probably removed the loose ends instead of buying the warmer surroundings.
Is there any write up on how to re-connect this on this or othe forums or a wiring diagram?
Any help will be much apriciated! :)
