need more top end
chitownrx-1
carol stream IL
i have an 03 rx-1 with arctic cat zr rear suspension, air filters with evac and a bender clutch kit. i am only seeing around 110 mph on dream meter. the problem i am having is the thing is just nuts out of the whole. i was wondering how i would be able to take that power and move it to the top end. can i do it with the clutch or do i need to do it with the gears. thanks matt
loosen up the track. it has anti rachet drivers on it. I told you the night you bought it from me. it takes the track to be pretty loose be for it will rachet
We need a lot more info to help. What is in the clutch kit, What rpms are you running, what is the gearing. Have you checked over the whole sled for wear/adjustments . Has someone put a manometer on the sled to balance the carbs.
