- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I'm updating one of the first Bender RX-1 Stage 2 kits to run the oil system off of the engine (this is one of the first kits which had an oil tank in the rear with the pump feeding oil to the turbo out of this tank). What I need is a picture or two of the nose area of the sled where the oil return pump gets mounted! Thanks!
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
Srxspec said:I'm updating one of the first Bender RX-1 Stage 2 kits to run the oil system off of the engine (this is one of the first kits which had an oil tank in the rear with the pump feeding oil to the turbo out of this tank). What I need is a picture or two of the nose area of the sled where the oil return pump gets mounted! Thanks!
I don't have any pictures but I can tell you that the scavange pump is mounted up in the nosecone, where the rectifier is mounted.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Thanks Ted, I did one of these about a year ago and should've taken some pics! I've got it all laid out and think it's all in the correct places. Been fighting a head cold for over a week and it's starting to take a toll on me, can't think straight!
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Srxspec,
Ted is correct. It mounts up in the nose and dumps back into a T in the small oil line at the top of the oil tank...
