Need Some Help Please!
yox185 said:
Just take out the tank and you're good to go. See having a Doo did come in handy! Have a good trip.
Hahaha....it sure did! I learned more than I would have liked to know about doos in my past few years!
I wqs at the Hitching Post in Hopkins, MN on Saturday and they had cr10ek's in stock or call Ulmer he has them too.
Well, since we are leaving in the morning I just picked some NGK CR9E plugs....it's what comes with it stock. It was a bit of a process to change the plugs but well worth it to hear it purrrrrrrrrrr again when I turned the key! Thanks guys I appreciate your help
When you hear the fuel injection pressuring up, that should tell you do NOT touch the throttle until you get it running. If you squeeze the throttle, gas shoots into the cylinders and floods the motor out. In severe cases, you can get hydrostatic lock and it won't even turn over until you remove the plugs to relieve the cylinder pressure. The TORS can be tested after the engine is running, just don't do it before you start it. Wig
