bigdog_mike
Well it finally died on me this summer 2006 apex battery, so I need to replace it, do I just go with a Yuasa battery for the apex or is there a better model that will atleast last as long as the original factory battery. Either way I will have to be dropping some cash into its replacement, then since I have the sled tore down, may as well change the oil, but I only have 1500 miles on the current AMSOIL synthetic so maybe not. Any help on the battery purchase will be appreciated.
great white north
I have a 2006 apex gt with original battery. Oem is fine, you just need to have a battery tender on it when it is not in use for extended periods of time. That is the trick with any battery. Just my opinion.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
bigdog_mike said:Well it finally died on me this summer 2006 apex battery, so I need to replace it, do I just go with a Yuasa battery for the apex or is there a better model that will atleast last as long as the original factory battery. Either way I will have to be dropping some cash into its replacement, then since I have the sled tore down, may as well change the oil, but I only have 1500 miles on the current AMSOIL synthetic so maybe not. Any help on the battery purchase will be appreciated.
X2 on the battery tender, great little investment and only charges the battery when needed.
I would stick with Yuasa batteries, they are probably the best or one of the best batteries you can currently purchase fir these sleds.
I would also change your motor oil while your in there if it is older than a year old, I know it's synthetic but even Amsoil recommends a 1 year interval even though the milage may have not killed it yet.
mooney26
Same I'm running stock 06 battery on my APEX-GT and also use the tender works great I'd stay with stock.
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
I have EverStart premium sport AGM model ES14BS. This is a battery that you can get at Walmart that I have used in other sleds and ATVs. They last 3-5 years no problem. Otherwise you can purchase the Yuasa original for a higher price tag, but I have not had a problem even in extremely cold temperatures as long as it is AGM type battery.
