Need torque numbers for front suspension and subframe
rayone02
adrian, mi
2012 Apex 2012 nytro xtx 2006 attak
Need torque numbers for front suspension and subframe. Thanks for any help.
List
A-arm bolts
main steering linkage on subframe
List
A-arm bolts
From the 2008 FX Nytro RTX Maintenance Manual,
A-arm top bolt - 32 ft-lbs
Top (frame) and bottom (a-arm) shock bolts - 32 ft-lbs
A-arm bottom bolts - 47 ft-lb
Pivot Arm bolt to frame (with cottor pin behind nut) - 48 ft-lbs
