rayone02 Lifetime Member Joined Dec 3, 2010 Messages 425 Reaction score 31 Points 858 Location adrian, mi Country USA Snowmobile 2012 Apex 2012 nytro xtx 2006 attak Jun 1, 2013 #1 Need torque numbers for front suspension and subframe. Thanks for any help. List A-arm bolts main steering linkage on subframe D Dodge Ram Expert Joined Jun 25, 2012 Messages 261 Reaction score 2 Points 73 Location Canton, Michigan Jun 1, 2013 #2 I had the same question. But I just tightened them up till very snug. They being the control arms. ALuCsRED Extreme Joined Oct 28, 2009 Messages 81 Reaction score 2 Points 488 Location Brandon, Manitoba Jun 22, 2013 #3 rayone02 said: Need torque numbers for front suspension and subframe. Thanks for any help. List A-arm bolts main steering linkage on subframe Click to expand... From the 2008 FX Nytro RTX Maintenance Manual, A-arm top bolt - 32 ft-lbs Top (frame) and bottom (a-arm) shock bolts - 32 ft-lbs A-arm bottom bolts - 47 ft-lb Pivot Arm bolt to frame (with cottor pin behind nut) - 48 ft-lbs You must log in or register to reply here. Similar threads S Subframe bolts Torque specs sbr6768 Mar 3, 2014 FX Nytro General Talk Replies 6 Views 3K Mar 6, 2014 sbr6768 S Nytro Subframe Removal Procedure grizztracks May 17, 2013 FX Nytro General Talk 2 Replies 27 Views 28K Mar 5, 2018 stephent59 T torque spec for subframe installation tjp Mar 18, 2011 FX Nytro General Talk Replies 2 Views 1K Mar 18, 2011 tjp T M Subframe bolt torque markowinnipeg Feb 4, 2012 FX Nytro General Talk Replies 2 Views 1K Feb 5, 2012 markowinnipeg M need skid plate mounting hardware for my 08 nytro snopro442 Sep 2, 2013 FX Nytro General Talk Replies 6 Views 2K Sep 30, 2013 herndonp Share: Facebook Bluesky LinkedIn Reddit Pinterest Tumblr WhatsApp Email Share Link
