Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Best way to fix ski lift....twist the bars Into the ski that's lifting, and continue about your business.
Way too many variables. The afternoon could dump 3" of powder and then you'll be worried about skis pushing.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I do the same. With adjustable shocks, it makes tuning front end roll much easier.I find the inside ski lift i can dial out by softening up the compression settings on the ski shocks without spring adjustments.
I switch back and forth between soft and medium compression rate on the ski shocks quite a bit.
It seems that the Qs-3's need another setting between 1 and 2 as I was constantly going between the pair when I used those shocks.
