RAMSOMAIR
Just put a new 8JP belt on my Sidewinder after 7500kms of trouble free miles and it seems to sit too low with far too much deflection. Stock spring set at 3-3. BOP secondary belt adjuster backed all the way off.
Is there any way to get the sheaves closer together on the SW clutch?
Belt squeaks a bit at take off sometimes.
RAMSOMAIR
jagger2014
- May 1, 2015
- newfoundland
- 2018 rtx se
tighten up your belt adjuster to raise belt in secondary... its backed off to far
RAMSOMAIR
Tightening it up pushes the helix out and drops the belt!
Fast
- Sep 25, 2018
Need to remove a washer or two behind the secondary boltJust put a new 8JP belt on my Sidewinder after 7500kms of trouble free miles and it seems to sit too low with far too much deflection. Stock spring set at 3-3. BOP secondary belt adjuster backed all the way off.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
With adjuster backed off against the large washer, is there free space between helix and adjuster?
RAMSOMAIR
I will check when I return to Canada.With adjuster backed off against the large washer, is there free space between helix and adjuster?
Fast
- Sep 25, 2018
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I find it best to run it SLIGHTLY under the sheaves. Each belt is slightly different but running it sitting over the sheaves IMO makes it harder for all rollers to contact helix ramps. Maybe others have seen this but when I drop it down slightly my rollers are tighter to ramps? Just a observation on mine. Maybe not the same for others.
Fast
- Sep 25, 2018
I would say the magic spot is .5mm above the secondaryI find it best to run it SLIGHTLY under the sheaves. Each belt is slightly different but running it sitting over the sheaves IMO makes it harder for all rollers to contact helix ramps. Maybe others have seen this but when I drop it down slightly my rollers are tighter to ramps? Just a observation on mine. Maybe not the same for others.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Could be. Very dependent on which belt.I would say the magic spot is .5mm above the secondary
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
Could it not also be depended on your center to center measurement?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Yes. Belt length and width also
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Google snowmobile belt deflection, measure it
RAMSOMAIR
I did as Dan said and ran the sled on the lift for a while with the belt adjuster backed right off and everything seated as it should. Belt is just flush with top of sheaves and all is good. I guess I didn’t run it after putting the new belt on. Thanks for all the tips guys.
