New Dyno Record 404 hp MC Xpress
yes it is the 404 hp motor in that warior
Your funny :D Money is not the issue , I just like to know what crap is worth and if its worth it :ORC Especially in this overpriced sport I enjoy just to dam much. :Rockon: :Rockon: ;)!
It´s the 340 hp version according to CG himself.
Den där filmen är från ifjol, med 340hk...å den mindre turbon.
Det va inte allt för lång respons...och det är ju nu botat med lustgas i början...
Skotern ä ju egentligen inte byggd för "ledkörning" utan för att vara så snabb som möjligt i dragracing
"This movie is from last year,with 340 hp ... and the smaller turbo.
The lag wasn´t too bad... and it´s now cured with NOS.
The sled isn´t realy built for trailraiding,it´s ment to be as fast as possible
in dragracing."
in dragracing."
Thanks for info Hooper
Anyone use a boondocker n20 kit on a bender turbo>.... just installed one, have a couple questions about need to rejet...
Turbo Time.... thanks for reply... 1. you apply the n20 while under boost or do you use it only out of the gate from a dead start.... As i understand the system, I am a little fearful that while under boost, the presure from the n20 block will not be enough to off set the peto tube prresure, thus leaving the system lean while under boost >>> 2. About how many good 4-5 second blasts can you get from a bottle until the presure is to the point of little gains..... no where in my instructions does it give a hp gain....leaving it difficult to caculate bottle run time... Also, my bottle looks darn hear level on top of the head,,, is yours the same and if so, any problems with the pick up tube in the bottle losing the liguid n20 after the bottle is half gone ?
3. did you have to change your main jets in tuning the n2o.... maybe drop me a line at campflake@frontiernet.net thanks kip
You haven't missed much. Not real exciting. Watch Mr. Sled's Rib Lake Video of the 138 mph Turbo RX-1. That is a better movie. Although a little short.
MCX
The standrd kit comes with the " Mitsubishi 16T" - 300HP
and there is an upgrade to a volvo " 3kMCX400" - 400HP
Im sure that if your willing to pay for it they might sell a - 3KMCX500-500HP in a kit
