TD Max
Stopped by to see Jason at Muffin Works this weekend. Picked up a pair of the billet suspension spring adjustment cams, a copper exhaust gasket for just in case, and his poly bracket for the Fox air pump.
Add this to the HID kit from Yamaheater already here and the MBRP trail can. HID kit was no brainer. Can I could have done without, but not wanting to mess with the potential failure of the OE muffler...
Next up: Dupont slides and rear wheel kit.
I was thinking of those sliders but if those don't give then your track clips will wear more. So not sure if that's a good idea either.
Reg sliders are cheap and easy to change. Change them half way through winter also if u want. Only $40 a pair
I've been running the DuPont hyfax on a 141" 1.6 cobra and they are fine. Clips are looking great , hyfax is wearing much slower than the cat sliders did and the track looks good. No crazy wear or issues. Don't buy into all that some have said regarding the DuPont hyfax including needing a fully clipped track. I have seen no issues or downfalls to running them, except for the price -)
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
Got a bunch of stuff coming for mine, anyone have a Skinz Viper muffler yet? Looking to order the Super Q...
- Apr 14, 2003
- Hessel, Michigan
Same here.....DUpont slides and rear wheel kit
Monsey
How many miles/km's are people getting on the stock sliders ? on my previous Phazer i would go through a set of sliders every 500-1000km's (depending on conditions). I put Duponts on it about 3000km's ago and they may have worn 1/8th of an inch since. To me they are the best thing in the world.
I now have about 2500km's on the viper and its approaching the wear line, I will replace them with Duponts when its time.. just not sure how long people are getting out of the regular sliders and when I should expect to do them, before the season starts, or if i'll get another season out of them.
Studroes144
My stock slides were totally shot at 500 miles..they had several wavy spots in them and on the front bend they were almost wore thru. Duponts were on for 1800 miles and they look brand new! They haven't wore a bit and track clips are in perfect shape. Duponts r expensive but a great investment if u plan to put on some miles
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
3200 miles on stock slides and still going strong.
Studroes144
Shagman what model is your sled?
Studroes144
And suspension play a huge factor too! Too stiff and it'll wear right through the slides. That was my issue
shagman
Vendor
- Feb 18, 2014
xtx. i also run the track on the loose side of the specs.
- Apr 14, 2003
- Hessel, Michigan
Same here....2,800? miles or so and they look real good yet! But I want to free up some power so I will be getting Duponts. I rode with SHagman most of the time and the snow was incredible! I run my track a little tighter than Shagman. XTX here also, same as Shag.
Yamadog
I have 1500 on mine and look like I can get another 1000 easy on my XTX. I think the snow condidtions and track tension play a big role.
TD Max
https://www.youtube.com/watch?v=yIwPKGhB-ho
Decreased friction between hyfax and sliders is decreased friction. Both should last longer.
Studroes144
Just look at it this way..decreased friction and less rolling resistance equals increased fuel consumption and a faster more responsive sled. For $130..why not?
Studroes144
Yes they do I had mine on for most of the season. I bought mine right off eBay
