yamatyb9
Just picked up my first rx1, used to my 2 stroke vipers but the better half wanted e/s and a 4 stroke so had to make her happy! Got an '03 with 2700 miles for 1900, thought that was a great deal?? Only thing it needs is A new spindle/right knuckle on the ski. Wondering what maintenance I should check or do, obviously some different things than the 2 strokes.. Just checking what major things to keep up on? Thanks!
blkhwkbob
Funny, I'm in the middle of replacing a right knuckle right now. Advice: while you are ordering parts, take a good look at the bolts holding the control arms to the knuckle. Mine were bent in a S shape!
Other: exhaust donuts, add an Apex seat and riser for comfort, check the jackshaft bearings-try to see if the clutch side has been updated with the locking ring, clean carbs and keep them clean.
yamatyb9
Thanks, appreciate the feedback!!
check if some one has done some clutching as the rx's needed some from the factory
RxThunder
blkhwkbob said:Funny, I'm in the middle of replacing a right knuckle right now. Advice: while you are ordering parts, take a good look at the bolts holding the control arms to the knuckle. Mine were bent in a S shape!
I agree on the Apex seat and riser big time! Just curious as to what you're refering to with the clutch side bearing having a locking ring? Also I have 4500 miles on my 03, doing exhaust donuts this year and the only bearing I have never checked or replaced is the one behind the primary, any tricks or tips?
dmaxx
- Apr 5, 2006
- sw Michigan
- 2014 Apex XTX, 2012 Apex SE, 2000 Vmax 700, 2000 AC Z-370, fast
- White Pigeon, MI
RxThunder said:blkhwkbob said:Funny, I'm in the middle of replacing a right knuckle right now. Advice: while you are ordering parts, take a good look at the bolts holding the control arms to the knuckle. Mine were bent in a S shape!
This is a well discussed topic here, many posts available. The jackshaft bearing behind the secondary. RX1 was updated with a locking collar and sleeve in 04 as the 03's had a tendency to slip out on the original tapered collar. I know this first hand, happened to me. You can inspect behind the bulkhead and get a visual on the locking collar. Just order the updated parts kit, the bearings are the same.
blkhwkbob
dmaxx has it covered.
As far as the exhaust donuts--the front two exhaust screws under the seat---start spraying them with PBblaster like yesterday. If the heads strip out it is a MAJOR pita to get the rest of the job done. In fact, I would hit those with a hammer-type impact tool right off the bat (after pbblaster).
blkhwkbob
Bigfish
- Sep 7, 2009
- 15 RS Venture TF
04 RX-1 ER
blkhwkbob said:dmaxx has it covered.
and replace them with hex-head bolts, so you don't have to go through it all again next time!
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Every one talks about these being a problem but I just put the right allen head in the bolt and with a small effort they turned with no problem and no and no anti penetrating oil of any kind. I changed he donuts one time then the titainium pipes later on with no problems. After 18,000 miles I could take them out with no problem right now.
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
Bigfish said:blkhwkbob said:dmaxx has it covered.
I like allen head bolts better then hex head. I'm changing all the bolts on the motor of my 68 to allen head except the head bolts and internal bolts. I think like the phillips screws that everyone has so much trouble with it all boils down to using the right size tool. If you use standard size allen wrenches in a metric allen head bolt its going to strip. Same as using a #2 phillips screwdriver in a #3 phillips screw your going to have problems been there done that.
Sometimes a little heat is your friend on stubbron bolts.
blkhwkbob
I actually didn't have any allen head tools at all so I tried getting them out with a potato. It works so well getting out broken light bulbs I figured it would work here, too.Sasquatch said:blkhwkbob said:dmaxx has it covered.
Bigfish
- Sep 7, 2009
- 15 RS Venture TF
04 RX-1 ER
Sasquatch said:Bigfish said:blkhwkbob said:dmaxx has it covered.
Mine were a total PITA. Used heat, penetrating oil, etc. Ended up drilling them out and tapping new threads a size larger, then replacing with SS hex head bolts. The only ones I found that were harder to get out were the exhaust clamps that join the muffler assembly to the exhaust pipes. I think mine were welded in!!!
