Steini84
- Feb 2, 2014
Hello i have a 2018 sidewinder 153 btx le with a 2,25" lug powerclaw track with 3.0 pitch
I want to buy a camso peak 154x15x2,5"track but it only come in 2,86 pitch... I belive my sprocket wheels have 8 tooth
Does anyone here have a good solutions to my problem and where to buy the parts for this solution?
Does this model use a hex axle? and what is the diameter
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
9 tooth 2.86 drivers & shaft out of a RTX or LTX model will swap right in.
Steini84
- Feb 2, 2014
Thats a good and easy solution to my problem but is there anyone that produces sprocket wheels so i can buy two with originale set (8) with tooth, i want to keep the originale gearing if posible9 tooth 2.86 drivers & shaft out of a RTX or LTX model will swap right in.
- Nov 29, 2009
- sabattus, maine
You're in between,
for example using 1to1 shift at 8800rpm and 24/50 gears
3.0 8 tooth: 96mph
2.86 8 tooth: 92mph
2.86 9 tooth: 102mph
Pick your poison or regear
3.0 8 tooth: 96mph
2.86 8 tooth: 92mph
- Apr 17, 2003
- Menno, SD
- Menno, SD
With a 154 x 2.5 track you could go with a 8 tooth 2.86 pitch.
https://shop.avid-products.com/esho...oduct_1726205.2012-2018_Arctic_Cat_286__3.htm
Just make sure you choose 8 tooth 2.86 pitch.
- Apr 17, 2003
- Menno, SD
- Menno, SD
The driver diameter (circumference really) is not the same on a 8 tooth 3.0 pitch vs a 8 tooth 2.86 pitch.
8 tooth 3.0 pitch is 7.50" in diameter.
8 tooth 2.86 pitch is 7.125" in diameter.
9 tooth 2.86 pitch is 8" in diameter.
