New Camoplast Ice Cobra 1.6" with 2.86 pitch
Pbadgley
Inuvik NT
Canada
2004 Yamaha RX Warrior
I would like to try this new track out on my RX-Warrior but it only comes in a 2.86 pitch configuration. I did the math and when compared to my stock 2.52 pitch with 9 tooth drive to a 2.86 pitch with 8 tooth is less than 1% larger in diameter .88% to be exact. So I know this will be close to stock and going from a 1.25" lug to a 1.6" lug should not affect the front heat exchanger clearance.
My question is who manufactures a 8 tooth Extrovert drive sprocket with a 2.86 pitch that will fit a stock Yamaha shaft.
Also the track does not come in a 136" length but a 137" instead. Will I run into tension issues with a 1" longer track? I'm running an AD-Bovin ZX2 Skid btw. I would assume not since I want to use extrovert drives.
Track
I had that set up with a Ice ripper track 137'' and 2.86 pitch with 10 tooth drivers and the track stretch to the point that I couldn't adjust it anymore. So I assume that with smaller drivers it will be worst.
