New Tuner secondary
Ted Jannetty
Waterbury Ct.
Website
www.jannettyracing.com
All new complete billet secondary for Yamaha Apex and RX1. A simple bolt on that utilizes the old style OEM Arctic Cat helixs (1981 thru 2004) and springs providing a much wider variety of tuning options. The TUNER is made from T6061 aluminum and heat treated steel hub and towers. The movable sheave has reinforced towers for the higher HP applications when needed. It also has a belt deflection adjuster (no shims needed) and non wearing rollers.
The TUNER will be available in 10.6, 11.0 and 11.25 diameters. Specify when ordering.
You will grin to ear when you pull the trigger with a TUNER. We now have the TUNER for the RX1, Warrior, and Apex.
Price is 545.00 plus tuning parts, ie helix and spring.
ted do you know what the stock size is?will there be longer belts for the bigger diameter?
Tedis correct these secondaries are wicked out of the hole. Plus I get to use my old cat stuff again. options here are low gears leaving or put big gear in the chaincase and still be acceptable leaving. radar running this is going to be great
