TAP/ STM billet front clutch BAD TO THE BONE
Ted Jannetty
Waterbury Ct.
Website
www.jannettyracing.com
This has got to be the the bargain of the centry.
This All billet, full adjustable race clutch, includes all the tools to work on it, shims, hardware and all for 1250.00.
All new RAGE IV billet 4-arm quad primary clutch. Available for the Yamaha.
Rigid reinforced design for higher horsepower applications. The RAGE IV is now a reliable option to the three arm clutch. With the new generation high HP lower RPM engines today the three arm has had problems of button, roller and cam arm bushing wear. Another disadvantage is having to use giant oversize cam arms to pull the lower RPM high HP applications. With four arms you can add 33% more weight and distribute it more evenly and smoothly across four towers creating less wear on buttons and rollers, thus a more consistent shift.
The billet spider cover and movable sheave are made from 6061 T6 grade aluminum. The cover is designed to use Skidoo, Arctic Cat or Polaris springs providing a wide variety of spring rates to choose from.
