Newbie 4 Stroke owner here, looking for info
He must be out of stock i would call him... Click on Instructions and then click oil filter kit to see it.
Ok guys, So far (72km on sled now) I put a taller mid height 16" windshield, one extra set of wheels on the inside near the middle high wear area, Put on a set of wire type ice scratchers, 2" rox risor, and a set of Nytro Hand guards, and I removed and painted my hood vents blue to match sled, I widened out my front skid's and pulled limiter strap tight, adjusted spring tension and finally installed some Blue Led's......
Do you really need the limiter straps tight? I set mine at the 3rd from bottom hole... havent tried it yet, but it came from factory all the way loose!?!?!?
Ok, I should have said it better, I pulled the strap tight while the sled was sitting on the snow, it was on the last hole and i moved it down 2 more holes....
