07 GT
I just bought a leftover 07 Apex Gt. My question is can you tip these sleds on their sides for service??? Like changing hyfax, or will it damage something?? Im used to tipping my 00 SRX on its side for changing slides or greasing it.
Do you need to remove the plastic side panels to tip it on its side?
Thanks.
Thanks.
ApexSS
I've heard you can and people do. If you search you'll find it.
ApexSS
rightarm
I believe that you should only tip them on the right side,but you don't need to do this to change the hyfax.
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
Correct, you can tip them throttle side down without any issues. If you tip them brake side down, oil will leak out.
SharkAttak
rightarm
A slide hammer aka body puller attached to the end of the slide and wd-40 sprayed on the slides helps removal and install.
SharkAttak
rightarm said:A slide hammer aka body puller attached to the end of the slide and wd-40 sprayed on the slides helps removal and install.
you are right, the slide hammer work's the easiest
