Newbie question
07 GT
New Glarus, WI
I just bought a leftover 07 Apex Gt. My question is can you tip these sleds on their sides for service??? Like changing hyfax, or will it damage something?? Im used to tipping my 00 SRX on its side for changing slides or greasing it.
Do you need to remove the plastic side panels to tip it on its side?
Thanks.
the hyfax are a nightmare to remove cause they are so wide so the last time i replaced them i went with old style they are not as wide fit thru the track hole easier and less drag
A slide hammer aka body puller attached to the end of the slide and wd-40 sprayed on the slides helps removal and install.
you are right, the slide hammer work's the easiest
