Grassfirebob
Sled starts runs fine but no lights. Dash is fine, fuses are good.
Where to start?
Thanks!
Where to start?
Thanks!
Super Sled
- Feb 25, 2009
- Summit X
You checked all fuses? If they are good then possibly a wire rub through.
Grassfirebob
I'm not en electrical expert but I would've thought that if the fuses are good, it's not likely to be a rubbed raw wire (otherwise I'd expect a short & a blown fuse). Makes me think likely a connection or ground but I have no wiring diagram so I was hoping others who have had the same problem might give me some "likely" places to start looking.
Thanks again,
Bob
Thanks again,
Bob
Super Sled
- Feb 25, 2009
- Summit X
Good point GrassfireBob. I'm thinking back to days on the 2 stroke Viper -- wire rub throughs we're often the culprit for those types of issues. Just trying to help.
turbozrocks
- Feb 19, 2009
My vote is a frozen headlight relay.. just happened to me yesterday!
Grassfirebob
It's been in my heated shop. I just swapped relays with another sled & that didn't help. I'm looking at the connection that goes from the sled to the headlight pod. Anyone know the wiring diagram for that connector? I'm guessing black=ground, red=power, green & yellow=power to the headlights.
If that's the case, I have power to the red/white (12v), & power to the red/black, but nothing else. Doesn't matter if the sled is running or not.
Grassfirebob
Just swapped ignition switch w another sled. Rule that out.
Swapped entire headlight/dash pod- rule that out. Swapped out all 4 relays. Rule that out.
Tested & have power to the fuse.
NEW: wiggling headlight pod connection, lights flickered. Thought sure I was on to it. Shut off sled, inspected, turned key to power (but not start position) & lights lit! (thought sled had to be running but apparently not). Wiggled briefly & lights out.
Really could use a wiring diagram.
Fergie
- New Jersey-Ride Old Forge N.Y.
I believe the sled does need to be running for headlights, I would start checking wires for a short.
IH8CROWS
- Jan 19, 2009
- Wisconsin
- 11 Apex
16 Apex
I have the 2011-2012 service manual with the diagrams.
PM me and when I get home I will send u the link to download.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
The engine needs to be running to energize the load control relay (relay #59 on my schematic). The load control relay switches power directly from the 40A battery fuse #4 to the 3A dc accessory socket fuse #53, the 20A headlight fuse #54, and the 10A tail/brake light fuse #55.
Do you have power at your dc accessory socket with the engine running? If not, I would suspect the load control relay or the 40A battery fuse #4. However since you said that you had the headlight on momentarily with the engine off I would highly suspect the load control relay.
